keihin vb 33A Carb
12K views 14 replies 6 participants last post by  LorneP
#1 ·
Noobie here for the first time. A buddy and I picked up a 79 cx500, with extra parts including an engine and a keihin vb 33A carb. I know this does not fit the cx500, but can not find what it does. Any suggestions?
Our build will be delayed until spring, but lots of reading research is being done. Will follow with pics and lots of questions. This is a great site. Would not have even thought of taking this project on without it!
Lorne & Tom
http://cx500cafeconversion.blogspot.ca/
#3 ·
This is a list that was being built at one time. I don't know if this is where it stopped or if there is more.
VB1AA-A ..... CX500 E-C, GL500 D-C
VB2AA-A ..... GL650, GL650I
VB2AB ....... CX650 C
VB2AC ....... CX650 C
VA2AC-A ..... CX650 C
VB2BA-A ..... CX650 E-D, GL650 D2-E
VB23A ....... CX500 D 1979
VB25A-B ..... CX500 C 1980
VB25A-C ..... CX500 C 1981
VB25A-D ..... CX500 C 1982
VB26A-B ..... CX500 1978
VB26A-B/C ... CX500 1979
VB27A ....... CX500 C 1979
VB28A-B ..... CX500 D 1980
VB28A-C ..... CX500 D 1981
VB29A-A ..... GL500, GL500I
VB36A-A/C ... CX500(UK)
VB36A-E/F ... CX500-A
VB36A-F ..... CX500-B
VB37A-D ..... CX500 C B
#6 ·
They sure look like cx carbs. Did you check to see if they fit?
Also can you measure across the rear where the bracket holding them is missing. End hole to end hole. And how far the inside of the carb throats are from eachother. Then I can compare to carbs I have here.
#7 ·
ive a set of vb36ac in front of me and they look very very similar almost identical
not on larrys list thou
Model....... CX500(UK) CX500 1978 CX500 1979
Number.... VB36A-A/C VB26A-B VB26A-B/C
Model....... CX500-A CX500-B CX500 C 1979
Number.... VB36A-E/F VB36A-F VB27A
Model....... CX500 C 1980 CX500 C B CX500 C 1981
Number.... VB25A-B VB37A-D VB25A-C
Model....... CX500 C 1982 CX500 D 1979 CX500 D 1980
Number.... VB25A-D VB23A VB28A-B
Model....... CX500 D 1981 CX500 E-C GL500 and GL500I
GL500 D-C 1981, 1982
Number.... VB28A-C VB1AA-A VB29A-A
Model...... CX650 E-D GL650, GL650I CX650 C
GL650 D2-E
Number....VB2BA-A VB2AA-A VA2AC-A, VB2AB,
VB2AC
#8 ·
As 'stich said, they do look like CX/GL carbs.
Could they be for the oddball German Restricted CX500 or GL500? They had a version which had the HP kicked down to conform to their new rider or student laws.
Maybe the 400cc incarnation of the engine?
Or MAYBE, you somehow got a hold of those 150MPG carbs that the oil companies all paid to have recalled and destroyed. Beware if it's those, the kill orders are still out, I hear if you wrap them in foil and wear an aluminum foil hat the black helicopters won't be able to track them.
#12 ·
Hi Murrayf, sorry to hijack tread but need murray to PM Gerard need to get a in touch with you, seems something not working at my end Thanks guys.Gerard
