Before I cut these off (photo #1), these are just some sorta clamp for mirrors, right?
Got the nut off, can't get the thing apart. Bashed the threaded end with a hammer, doesn't budge, put a screwdriver in the hole on the left and turned but doesn't thread outwards, just turns. Off-chance these are for something, I wanted to double check, otherwise, apart from removing everything on the handle bars and sliding them off (one on each side) I'm thinking it's cutting time.
Bought a new MC and clutch lever, they have the threaded holes for mirrors... though not entirely sure how to replace the clutch lever. It's not a separate piece like the MC, it popped off, new one popped on, banjo bolt seems to fit so just need to re-order the brake line and done (photo #2). The clutch lever though, looks like it's a part of the assembly for the horn and such. The new lever (at this link) has the plugs on the back, same clamp as the MC has. Swapped the MC out nice and easy, went to the clutch lever and figured best to ask before I dismantle it. Looking in the manual I'm not finding any diagrams for it... do the two halves come apart and the lever is inside? or is it all integrated?
