I suspect you have assumed that an engine serial number beginning with "CX500E-" means the bike is a CX500E but Honda model numbers don't work that way. The information on the page linked below may help you figure out which model you actually have
“Trying to figure out the year of your Honda CX500’s frame and engine? Find out here!”…
motofaction.org
Welcome to the forum. Please add your location and (once you figure out what you actually have) your bike's model and model year to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
