I feel like I've seen someone's bike on here with a set of stock ZRX rear shocks. Any problems with fitting them?
Scott
Yep, I can tell you first hand that the sportser shocks are MUCH stiffer than the factory ones. I spring my bikes for a very aggressive riding style, so it actually turned out darn near perfect for me, but it is probably way to stiff for most people.Thanks for the suggestion tvpeirce. I've thought about them before, though from what I recall they're on the shorter side. I was hoping to raise the rear end a bit. Also, Sportster's are heavy pigs, those shocks would have to be revalved and sprung for a CX...
You could find a set of ZRX shocks in the ZRX forum,I've seen them go from $150 to $275 a set recently.Thanks for the info in the PM. I've had a pair on my radar for a while, I'm hoping to find them for less than $300. I rode a friends Bonnie that had a set and they were definitely stiff! The stock ZRX weighs about 50 lbs more than a CX (I think). I guess the weight, and maybe distribution of weight calls for much stiffer springs than needed for a CX. About how much is the rebuild running you? Does the rebuild entail new springs and having them revalved? In total that might put them out of my budget, it seems they won't be very usable in the stock form? Might just be better off with a set of Progressives all around. From my research, ZRX's are the only bike I could find with good quality stock twin shocks. Most bikes with twin shocks seem to be cruisers, and I'm thinking the stockers don't seem worth it. Maybe Progressives all the way around is the best budget option.
Anyone have any feedback on Progressive springs in the forks (I have 33mm forks, 79 Custom). I'm wondering if new Progressive springs and a fork brace will give an respectable improvement in front end performance. I don't think a fork swap is in the cards for me, though that CB900 fork is definitely intriguing...
I tried some sportser shocks on my 81 cx500 and I am a good size boy and they were stiff as hell, I did switch to harley air shocks sit you up about half a inch bushings a pain to press out but the ride is so sweet. I am running them without any pressure currently. They are bulky looking but depending on look your going for very comfortable.
