Here are a few of my favorite things.
Cept what they cost
My favorites are the electrical cleaners corrosion inhibitors in the middle and I sorta explain below... What are your favorite Elixers ?
In the middle(r of the b-12 chemtool is a tube of silicon dielectric grease. I use this on sliding contacts (switches) De oxit d5 is a cleaner lube that I have used for years to keep connectors from oxidizing, under that is the Truck Lite dielectric compound which I put in connector blocks and at grounding points. next to that is a CRC QD spray (quick disconnect), I use that before I pull apart block connectors.
