1 - 11 of 11 Posts
Another one has found its way into the stable. 1980C This will need lots of TLC:BangHead:
Most likely will end up as son's bike, maybe a little cut and chop this time.
Land vehicle Vehicle Motorcycle Motor vehicle Chopper
Yup, I tell my wife all the time cycles are "a hearding animal" It's not healthy for them to be left alone leaned up against a tree/barn/shed. I consider myself a sort of Rescue shelter for the neglected abandoned and abused motorcycles of the area.
Discussion Starter · #4 · (Edited)
Just thought I show you guys what that rusty junk pile (the thing) turned into.
1980 cx500 custom $100.00 (this was supposed to be a cheep budget build) turned out the only positive was a titled frame, almost nothing was salvageable.
PURCHASED PARTS new or used from cheapest source possible
battery 34.99
turnsignals 22.85
flasher 2.45
mirrors 16.76
tail light assy 16.99
brake pads 8.00
master cylinder 26.83
clutch cable 11.89
choke cable 12.00
clutch lever 6.95
headlight mounts 11.20
superbike bars 25.95
foam grips 8.08
headlight bucket 28.00
brake pedal 28.00
fork dust seals 11.67
fork seals 15.00
wheel bearings 27.60
shift lever 9.00
rear tire 90.00
2-1 exhaust 264.00
ignitech 130.00
title,tax&lic fees 221.00
total 1074.23
REPLACMENTS FROM PERSONAL PART SUPPLY (**cost/value estimated)
replacement Motor 250.00 **
rocker assy's 25.00 **
cam chain 56.00 **
cam tensoner 48.00 **
oil pump chain 18.00 **
waterpump seal 38.00 **
gasket set 60.00 **
clutch set 40.00 **
motor alone -535.00-
rebuilt carbs 150.00 **
fuel tank 100.00 **
side covers 60.00 **
oil filter 4.00 **
air filter 8.00 **
Electric fan 19.00 **
e-fan relay 12.00 **
rear wheel 45.00 **
rear diff 45.00 **
front tire 40.00 **
head light assy 45.00 **
replace fork tubes 45.00 **
Total 1101.00
Total investment 2184.23 crazy:vs_lol: Vehicle Motor vehicle Motorcycle Mode of transport Transport
Auto part Engine Automotive engine part Metal
Vehicle Machine
Engine Auto part Vehicle Automotive engine part Car
Engine Auto part Automotive engine part Vehicle
Land vehicle Vehicle Motorcycle Car Motor vehicle
Land vehicle Motorcycle Vehicle Car Motor vehicle
So much for the budget! Bet you would do it again and probably will.
Now I'll give you a hundred bucks for it:D
Reactions: jak
battery 34.99
turnsignals 22.85
flasher 2.45
mirrors 16.76
brake pads 8.00
clutch cable 11.89
choke cable 12.00
clutch lever 6.95
foam grips 8.08
brake pedal 28.00
fork seals 15.00
shift lever 9.00
rear tire 90.00
2-1 exhaust 264.00
ignitech 130.00
total 1074.23
cam chain 56.00 **
gasget set 60.00 **
clutch set 40.00 **
fuel tank 100.00 **
oil filter 4.00 **
air filter 8.00 **
rear wheel 45.00 **
rear diff 45.00 **
front tire 40.00 **
Total 1101.00
Total investment 2184.23 crazy :crazy:
A small price to pay for time well spent and a job well done :)
Discussion Starter · #10 · (Edited)
Another one:violent1: Someone else's failed project is now my next. Also an 80 custom.
Engine Auto part Scrap Vehicle Car
Of the 5 motors (parts) visible (2) are boat anchors, (2) I'm confidant will run without much work, (1) Will run but needs comp overhaul.
I'm currently working on that one now, it will be satin Black with polished accents , carbs, clutch cover, thermostat housing and pipes and stainless bolts. To be installed in the "Blue thing" above.
Just picked up a new seat from Forum member slackerdeluxe, Looks Great
Land vehicle Motorcycle Vehicle Car Fuel tank
1 - 11 of 11 Posts
