1 - 8 of 8 Posts
Hey guys
i have been searching around for some time, and i just cant seem to figure out what specific year my CX500 is from.
the engine serial is CX500E-3003755
the frame serial is CX500-3003738
from what i have found out, most CX's got cx500-2####### or cx500-4###### or PC01###
i am located in Denmark, and from what i have been told it has been imported from Germany.
the bikes exterior makes me think its 79. but the e in the engine serial makes it a 84. but first registration was in 83 it say in the papers..
can someone shed some light on this ?
Engine maybe a transplant from a later model bike.
Look at the plate on the steering head, it will tell you the year of manufacture.
Discussion Starter #3
there is no plate there unfortunately, only a repetition of the serial i also got off the plate under the airbox
What you have is / was?? a German 27 hp restricted CX500. 1978. Those had frame- and engine numbers with a leading "3".
Also the first year model, as digit # 2 is a "0", indicating first year of manufacture. De-restricting is utterly simple,so chances are someone already has done the work for you.
I´ve consulted the German "CX bible", written by Frank-Albert Illg, and got all about numbers confirmed from there.
/Sture
Reactions: OCR
Discussion Starter #6
/Sture
Thanks alot for clearing that up!
How was it restricted? You are most likely right about it being done already but just wordering how it was done
The restriction is a welded-in "plug" or "washer" inside the exhaust downpipe / header, just after the joint flange. The restricted pipe is MUCH narrower inside - 15 mm.
Just ream it out (careful so you don´t take too much!) and you´ve got a nice, unrestricted CX. It´s said to be also something with the carbs (they have different No:s) but "the Bible" tells no difference in jetting etc. between the "restricted" and unrestricted carbs. Maybe it´s only some German legal finesse?
At least 27 hp German pipes have a stamp outside telling the power figure - I believe also the German unrestricted ones have it. Hence different spare part No:s for German pipes - restricted or not, vs non-German ones.
I ought to get a life! :D
/Sture
Yes, the 'full power' German pipes do have the power output stamped in them - I've got a new one in my spares stash.
There's nothing wrong with having the knowledge - it's only those that aren't interested (whatever the subject) who ridicule it. Those who need to know, as here, are (usually) very appreciative.
1 - 8 of 8 Posts
