1 - 12 of 12 Posts
If someone has a non-title or wrecked frame and will cut to small pieces off it, let me know. I need the two side pieces where swing arm bolts to. Project in the works. 1.jpg 2.jpg
I have a 81 gl500 frame that has no title. if your not in a rush it will take me a few days to dig out of the back of the back yard and cut the chunks out. if you can pay postage I will chop it out and send it to you no charge for the labor. how far outside this area in the pictures do you need the frame section cut?
Discussion Starter · #3 · (Edited)
No rush. About 2" in each direction would be fine. I need the circle part. If u have the set bolts to set the pre-load I would be glad to pay u for them. Just let me know. zip 35126 3.jpg
I had forgotten that I had to chop out the center section to remove the air shock to give to a friend of mine. If this will still work let me know.
So I got the second one cut off. this is what they look like. I also found the bolt that goes on the one side. Does this leave you enough material to work with?
1 - 12 of 12 Posts
