WTB CX 500 cam tensioner bolt
730 Views 9 Replies 4 Participants Last post by  bahn88
Mine Is apparently broken lol please help
1 - 10 of 10 Posts
Broken or stripped?
Is this the adjustment bolt?
Itll b engine out to replace
Cmsnl usually has these...but you should order a few things to reduce the impact of shipping costs....they do have Oem/oem spec cam chain guides and tensioner blades...
there are couple on ebay. one in UK and 1 in France
90087-415-010: Search Result | eBay
Reactions: 1
Broken or stripped?
The bolt is sheared. Everything else is ok. In the process of overhauling the engine seeing as though this thing has been sitting in a garage for 20 years. Discovered the bolt while doing so.
Your awesome man thank you!
The orings a bit of an unusual size....so replace that if it leaks its engine out to replace....or silicone externally each adjustment...
If you need a O-ring let me know I may have a couple left.
BTW: Welcome to the forum. Please add your location and your bike's model and model year to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
You mentioned overhauling the engine but you didn't say which manual you are using for that. The aftermarket manuals might get you through a job like that but the factory books for these bikes are so well written and laid out that the aftermarket ones should be considered secondary references only.
Thanks for the advice. I am using the Honda motor company manual for 78-82.
And believe me EVERYTHING that is old is coming off and getting replaced. (brake lines, fuel lines, hoses etc.)
I'll post some pics of the process when I get a little farther along down the road.
Got the rocker assembly out right now to clean all the carbon deposit and grime off. Want this thing to be like new when I'm done with it.
Might b a used one from this uSA seller....(disregard the postage estimate as it will b to OZ!)
Reactions: 1
1 - 10 of 10 Posts
