1 - 16 of 16 Posts
hi wondering if any one can advise i have seen a link to download u.s version of workshop manual does anyone have a link for uk version is there a difference or if there isnt a link advice on where to purchase one thanks
Discussion Starter #3
thank you for the reply I have recently bought a 1982 cx 500 trike. and having not owned a bike since early 90s I am out of touch with things although a car mechanic so not to worried about things but do want to get to know about my cx so i can maintain it properly and fix one or two issues it has i.e tacho not working, temp gauge not working and small oil leak from in at back above clutch casing i think. wish me luck lol
Motofaction says your engine is from a euro.
But it doesn't list your frame number which most closely resembles an 82 custom., but isn't actually listed on the site.
Usually the model is on the steering neck data plate.
Discussion Starter #12
So are engines the same am i right in thinking the cx500 is the predecessor of the gl500 or is there more differences
Same engine.
You have transisterised ignition.
Not sure whether the camchain tensioners are auto or manual on the UK model.
Here any motor with transisterised ignition is auto tensioned but the US GL is TI and manual tensioned.
To clarify: the CX500 as introduced in '78 came with twin shock rear suspension and Capacitor Discharge Ignition (CDI). The GL500, GL500I (Interstate) and CX500E (Eurosport but I believe just called "Sport" in the UK) came with Honda's Pro-Link monoshock rear suspension (rising rate linkage) and Transistor amplifier Ignition (TI or TAI).
If your engine came from a CX500E it should be identical to one from a GL500 except that the nameplates screwed to the sides will say "CX500" instead of "GL500".
BTW: Welcome to the forum. Please add your location to your profile and your bike's model and model year (NOT year first registered as your UP paperwork will show) to your signature so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
Oh, and we really like to see pics of bikes here so
200992
Discussion Starter #15
Thank you just replacedfork seal and all brake pads to get it mot'd now going to give it an overhaul and become familiar with as much as I can , it still has a few issues temp gauge not working, tacho not working and small oil leak as well as some paintworkhence why I'm trying to get as much info as possible
1 - 16 of 16 Posts
