Old connectors often only need a good cleaning to make them work better than new so unless the PO butchered the bike's original wiring it might be better off to invest in a can of real electrical contact cleaner and some suitable brushes for scrubbing inside connectors.
I buy cheap 1/2" paintbrushes to us for cleaning bike parts. The first one I usually pick up is one that I cut the bristles off at about 8mm or so long because it can often get into a lot of places that a toothbrush can't because of the handle orientation. I also use an unaltered 1/2" paintbrush or one that I have trimmed to a specific shape when longer bristles are needed to reach deeper into things.
