Hey guys first time poster here so if you need more info just ask. I have a 1982 cx500 custom. I have an LED headlight with integrated turn signals that I am trying to get to work. The main three prong plug works perfectly for the high and low beams. It's the remaining wires I'm having an issue with. I know which wires connect where but it seems as the wiring is "backwards". On the bike,with key on engine off, both turn signal wires (orange and blue) have constant power. The power only shuts off to that signal wire when the switch is set to the corresponding position. (power to the left signal wire turns off when I flip the left turn signal switch on ect...) When I plug my new light all up the turn signals stay on. Is there a way I can reverse this or do I need to fully rewire?
Thanks for you time, I know it was a long read.
Cheers
Cheers
