I have fooled around with charging systems for a lifetime now and have learned a few things. In this forum, I have read many accounts of post mortems on stators complete with well done pictures and circles and arrows. All are focused on the result of stator failures and how it happened. Normally the insulation breaks down and a coil either shorts to ground or opens somewhere. Again, this is a result...not a cause. Want to know why stators fail?
Most charging systems fail for the same reason...trying to charge an old, or nearly dead battery.
Think about it. The battery gets worse and worse. The system works harder to charge it, voltages go down and amperages go up. Gassing boils water out, causing corrosion on the terminals. Voltages in the battery drop due to poor battery condition at the same time that terminal corrosion makes it ever harder to get power into or out of the battery. The stator works harder to charge until finally somewhere, at the weakest point, amperages get high enough to melt insulation or the coils just arc to ground.
The moral to this story? It's simple. Do not buy cheap batteries. Do not keep your battery more than a couple of years...three at the most depending on your climate. Do not keep your battery on a charger for more that a day a month, ever! If your starter is dragging, check the terminals. If they are tight and clean, check the battery with some type of stress tester. When in doubt... replace it. It's a lot cheaper than replacing the stator and the battery together. If you are jump starting your bike, you are going to get to know a lot more about the inside of your engine than you really want to.
Hope this helps,
Capt Frank
Hope this helps,
Capt Frank
