We’ll I’ve seen this before on other manuals and I would go inlet 9mm and ex 11mm and how accurate are all the amateur mechanics at these jobs?…check cold and hot and depending on mileage do it regularly OK?The Owner's Manual says valve clearances should be .08mm/.10mm intake/exhaust.
The FSM says valve clearances should be .10mm/.12mm intake/exhaust.
...Which one is right? Which one destroys engines?
I'm new. I've never done this. I was just getting started. And of course I'm dead in the water looking at 2 sets of conflicting data. I'm searching this group for insight.
Owner's Manual:
FSM:
9mm is pretty wide...i know Murray said things expand but .......😉We’ll I’ve seen this before on other manuals and I would go inlet 9mm and ex 11mm and how accurate are all the amateur mechanics at these jobs?…check cold and hot and depending on mileage do it regularly OK?
Just set them cold to the spec in the FSM and be done. Why over complicate this?…check cold and hot and depending on mileage do it regularly OK?
