Hello there,
This post is a continuation of a previous thread I started on an pre existing thread regarding noise.
Link below:
www.cx500forum.com
For "quick" reference:
Bike is a Honda GL500 Interstate 82' TI.
Service done fairly recently. Valve clearance on the spot. New cam chain and tensioner. New clutch discs.
Bike had been running beautifully as a daily runner for 2 months or so. Went for a few "speed" drives too. Not a single issue. Bike was actually amazing me constantly and despite the lack of fairings she was happy out getting to 140kmph. Never had the balls to go any further as wind in Ireland is quite a thing and the rear solid rim just doesn't help at all. Silly me. Anyways...
On the last 3 weeks or so the drama begins:
Whining noise coming from the lower half of the front end of the engine. Assumed my oil pump was a bit too slack or worn, noise didn't sound too worrying, just annoying. I decided I'd get to it at some point.
progressively the noise gets worse, but still, daily commuter regardless. Annoying but not worrying. Every morning I'd get to 100 happily through the streets of Limerick waking up everyone on the way to work.
3 days ago i noticed a sudden loss of power. At first I thought I ran out of fuel AGAIN (she drinks a lot) but when put on reserve same issue happened, 1st gear starts OK but after a few degrees of twist on the throttle there is no more power despite higher revs, kicking in the 2nd provides the same, 3rd does push the bike but at a much much much lower speed, high rpm, and noise that reassemble the whinning of a horse just too tired to keep on pulling crap.
Yesterday the high pitch noise got much worse, I could swear it was from the top half of the front engine. Every now and then there'd be a high-medium pitch thumping. The loss of power was brutal. Constant whinning, and the rattle and thumping you'd get from a loose dashboard x10.
so far assessed nothing is lose. Currently trying to take out the fan (I had a puller bolt, I had to move houses, the bolt must have decided to stay behind) so I can assess the tacho unit.
Spinning the engine using the crank shaft inspection hole brings no noise in neutral nor 1st. If I however spin counterclockwise I do hear high pitch noises. Not sure if normal, truth be told all I know about bikes is thanks to this poor thing.
Spun the engine with the kill switch on and the clutch switch hard wired out of curiosity. No weird noise on neutral nor on 1st.
Sick of it had the bike running for a few seconds without the radiator, hoping without the rad on the way I'd be able to discern what's going on. No weird noise either.
it seems to happen only when over certain revs and moving...is it the speedo unit? Some might ask, nope, spun the front wheel, she happy too.
Removed the tacho cable from the deceased tachometer (why was I so stupid to leave it on knowing the tachometer was dead...?) No difference. Cable is absolutely fine and spins happily when turning the engine but won't let you twist nor pull if engine is not moving (I want to think that means it isn't broken).
My theories in avoidance of even thinking of the possibility of serious damage inside the engine are so far are:
Combination of the following:
My oil pump chain is messed up
My tacho unit isn't happy either (I had a incident going over a speed bump too fast and a lot of parts suffered the consequences, my fork seals blew, my gauges died, and both my fenders had to be replaced, even blew the main fuse)
my valves are just covered on grime.
This is really possible as it is one of the few things I haven't done yet, and it took me a while to get my carbs adjusted to the pods and custom exhausts, after I gave up trying to fix the older carbs that had leaks EVERYWHERE.
So...fully aware that without seeing the vrumvrum is a bit hard to discern what it could be. The idea here is wild guesses, that hopefully I haven't had myself yet, and all together by trial and error we might just find what's ailing my fat-fe racer.
Link below:
Dang Engine Noises......Whirring Whining!!!
Sorry, but the only time I removed the Camshaft Holder from an engine with the camshaft in place was to replace a leaking gasket and when the end of the camshaft pushed the holder downward as the last bolt came out (due to pressure from the valve springs) I was more interested in putting it back...
