41 - 60 of 87 Posts
Administrator
If you want monoshock, the best way would be to use a Yamaha XV920 shock, and weld up a bracket similar to the XV920's swingarm onto the CX500's swingarm. My next CX monoshock bike will be done that way.
Charles.
charles why would you choose shock technology the same age as tye bike you are building?
there is so much better stuff to swap in even a kawasaki ex650 has a similar install
its not known as a great shock but its at least from 2000 up
if you want the same set up style in a cruising version the kawasaki versys 650 or 1000 shock would be my choice
and you can get all sorts of springs ect
Administrator
I would choose that shock because it's already set up correctly for the swingarm leverage. Probably test it out and then find a new aftermarket shock to go with for keeps.
Charles.
Soooo.... what I'm getting from this thread is its better for me to just stick to dual shocks.
YES (emphatically not yelling), its no good to
overstep your skill level .
the result is disappointing at
least,,,,dangerous is almost
a certainty.(nobody wants to
fess up to this)
Which points out why CX cafes are more popular (prettier) than GL cafes due to the typical habit of CX cafes to cut the entire ass off said:
I'm sure you did,and point well stated.
Silliness(translated to
politically correct parlance) runs rampant
in the "custom motorcycle"
builds always has,,always will.
Duuuuuuh.
How else am I gonna sell my 800 bike for 5000 on Craigslist hahaha
Hey Charles PM me
If you want to toss some
ideas around.
I'm lookin for someone with
"Skill" to discuss the issue...
intelligently.
2 or 3 are better than 1.
P.T said lots of things.
"To the Egress" is my Fave.
"There's a Sucker Born Every Minute.
Money is in some respects life's fire:
it is a very excellent servant,
but a terrible master.
prolly the sucker
I'm curious about those KTM Duke mono shocks. the initial thought is that they are too "soft" since they have a (much?) larger rate of motion (spacing on the correct term there)? that would be the main concern with that particular shock? they seem like they would be sitting at a similar angle and mount position as to what i would ideally shoot for in a mono conversion and i haven't really found another modern bike with a similar swing arm with no linkage.
Thumper the guy that owns that bike had it built for him in exactly how he wanted it down to tge last minutiae It probably took him months to dream it out You dont build a cx for that kind of coin on spec they are built by contract for a specific owner I built one for a client over seas who even spec ed the valve Stems type So your comment about a sucker born every minute is very judgemental A 18 k dream achieved is very reasonable today I have done bike engines that cost more Go price a custom harleyOr a race ready busa,ect ect
Must be nice to have that kind of money to throw around.
How did I miss this thread!?! So my bike is recently completed and is basically everything you guys are discussing. My bike has the BBCR mono shock conversion with the EX shock. while building it I had a lot of concerns over the rear shock and found little about peoples results after the build so I'll toss in my two cents. I'm happy with the overall bike. regardless if its your cup of tea or not I'd do it again. Between the lightening of the bike and added performance its a drastically different bike than when it was stock. That being said I am disappointed with the rear shock for reasons everyone mentioned. its soft, too soft. This bike used to do decent wheelies and now even with all the performance gains the ass sinks when I nail the throttle. I put 1000 miles on the bike in stock form and have about 250 on it in the last week with the conversion. For me ultimately I believe I will end up having a shock built for my needs. I have tried 5 different shocks so far and they all create different issues. If your dream is to have a perfect suspension with infinite adjustment with spending no more than $30 on ebay for it I believe u will be disappointed. A lot of the conversions that I have seen where people are very happy with the results either have a pricey custom shocks or heavy invested in building proper suspension geometry to allow their shock to work as designed. Often I see people bock at spending x on parts when they only paid Y for the bike. Its all relative. Cx's are great bikes. Yes if u search u can score one cheap, but if you want to turn it into a heavily modified monster it takes more than pennies to get it there. I look forward to hearing more.
Administrator
Kevin, what I would do in your case is convert a gl500 swingarm and driveshaft, and then snag a gsxr1000 shock. The 1000 shock has the correct eyelet, and is pretty well matched. Put a hayabusa spring on it if you're a heavy guy and want more stiffness.
Note this is not a conversion for the weak. You'll need to sacrifice a cx swingarm to get the proper pivot point, and there is a lot of cutting and welding involved. You'll also need to fabricate a drive shaft with the front part of a cx shaft and the rear part of a go shaft. Ultimately though, using a pro link swingarm with a modern shock will give you absolutely amazing handling.
I'm not at home this weekend, but once I get back I'll post some pictures of the swingarm mods I did for my bike. It handles like it's on rails.
Charles.
In closing to me being retired $1000
is a lot of scratch.
To some people $100,000 is chickenfeed .
Anyone that places a high value on a custom
can invevest/spend however much they want.
In defence of Thumper I really don't believe
there was Intent to offend .
i did not say offensive i gently used judgemental
in thumpers defense its more a snap reaction
but tis forum is a isolated community formed to keep the cx running and shall we say on a very frugal basis
and the cx custom world is long past that just look at some of the bikes built
and the motorcycle world has long passed huge dollar customs
there is a waiting list at Arch cycle (keannu reeves and others) for bikes that start at 80k
mtt turbine is sold out till 2018 and theres start at 175k and who wants a stock one?
and so on
the value of a cx even changes across the world
it is not uncommon for a cx to have a value of well over 5k in austrailia and easily up to 10
and they will spend more on them and other bikes as they are collectors items and increase in value
here a cx used to be the low of low and now as a custom often exceeds 10k
the value of stock ones only seems to be rising as fodder for customization with a few exceptions in the edges
so sit back and watch its going to get interesting
but believe it or not a 18k cx500 is still in the lower end of the scale
41 - 60 of 87 Posts
