1 - 7 of 7 Posts
Ok, don't be too harsh.. just having a attempt at rebuilding a gl650 after much sourcing of various parts it's going really well. But at some point I've dropped a oil guide or something from somewhere... And I can't find where... I don't think it's from the crank bearing backplate but am happy for someone to tell me it is if they know 🤔
Are there any wizards who can pinpoint where the f this has fallen from!?
Thanks
Since you are asking about this in regard to a GL650 and they are normally aspirated I've moved this from the Turbo section to the Technical Help section.
And since this is the first thread you've started, welcome to the forum. Please add your location and your bike's model and model year (NOT year first registered as UK paperwork shows) to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
Note that while aftermarket shop manuals are pretty much necessary for people without factory training to work on a lot of makes & models of bike the FSMs for the CX/GL500/650 family of bikes are so well written & laid out that the FSM is really the only book you need and and even the best aftermarket books are secondary references at best.
I also recommend looking on all rubber parts with suspicion because rubber does not age gracefully. Check the date codes on your tires and replace them if they are over 5 years old no matter how good they look & feel (old rubber simply cannot flow around the irregularities in the asphalt well enough to grip, especially if it is cool or wet). The original rubber brake lines should be replaced every 2 or 3 fluid changes (= 5 or 6 years) so if your bike still has them I recommend shopping for modern stainless braided ones (they last practically forever and double the life of the fluid). And don't forget things like the rad hoses and the boot between the engine and swingarm (they can crack on the bottom where you don't see it).
· Premium Member
Be sure it's oriented properly when you reassemble. Narrow end forward.
Reactions: Sidecar Bob
1 - 7 of 7 Posts
