Wheel Bearings
1875 Views 6 Replies 3 Participants Last post by  Blindstitch
Does anyone have a source for the socket to fit the front wheel bearing retaining nuts? Is this another tool that I will have to sacrifice a socket to fabricate it myself?
1 - 7 of 7 Posts
Sorry I can't post a pic, but the old fashioned adjustable wrenches with the jaws at right angles to the handle are good for making these from, and of course they are adjustable for different sized retainers. The larger the wrench the better, 12 to 15 inches would be about right and you can always slip a bit of pipe over the handle for a bit of extra leverage.
Drill a hole into the end of each jaw about an inch deep to take an approriate sized shank from a high tensile bolt, thread the hole to suit the bolt, screw in tight and cut off with about 5mm of bolt shank exposed.
Get a bolt that is only threaded for the first inch so the shank that ends up exposed is free of thread, or shorten the threaded section before installation.
And the wrench can even still be used for it's original purpose.
I hope I have managed to make myself clear, as they say, a picture is worth a thousand poorly chosen words.
I may be wrong on this but I believe the front doesn't have any sort of retaining nut. It's the rear that does.
It's #7 on the rear.
The front wheel diagram doesn't look like an '82 GL500. My front wheel is picture below. it clearly appears to be a retainer. Pardon the super dirty wheels. I have not even begun to clean them up.
Woo Hoo!! got my frame swingarm & fairing bracket back from the powder coaters. It' beautiful!
Oops! forgot to add the photo! Doh!!
My bad. The cx's don't have retainers on the front.
These guys seem to have a similar problem even though it's not a motorcycle.
http://www.patrol4x4.com/forum/nissan-patrol-gu-gr-10/wheel-bearing-retainer-tool-front-21142/
This idea seems to be the cheapest/simplest one without a welder. Short bolts with nuts on them would work just fine.
1 - 7 of 7 Posts
