1 - 10 of 10 Posts
1980 CX500
Tire Wheel Cloud Fuel tank Sky
brand new to the forum. picked up this 80' Deluxe about a week ago, and joined the forum hoping for some answers and help for the issues I'm having. some backstory: bought the bike for $700, currently doesn't run but it turns over and starts up on starter fluid. cleaned out the carbs but currently waiting on a rebuild kit. thanks for reading, happy to be here.
Welcome aboard!
Use the rubber parts from the kits, but clean and reuse the original brass. It's much better quality than aftermarket.
Reactions: washoe
If it starts with starting fluid the problem is probably in the carbs. If you've tried to clean them unsuccessfully you should consider getting Larry's Carb Book
1980 CX500
Update: cleaned the carbs again (still waiting on that carb kit but I got impatient) and put them back on, the bike started right up. I’ll be sure to add my location and bike info to my profile. And as far as manuals, I got the owners manual and the clymer-type manual for the bike included when I bought it. This is my second antique bike (the first was an 81 CM400T) and I’m excited to see where this one goes
The Factory Shop Manuals for most bikes are written so that you pretty much have to be factory trained to understand them and an aftermarket shop manual is essential for the rest of us.
BUT that isn't the case for the CX/GL500/650 family of bikes. The FSMs for these bikes are well enough written that aftermarket manuals are at best secondary references and at worst (I'm talking about you, Clymer) liberally sprinkled with enough typos, errors & misinformation to make them virtually useless. Some would go so far as to say that the best use for the Clymer book is if one leg of the workbench is too short, but I say at least the coloured wiring drawings are easier to follow than the ones in the FSM so they are at least useful for that.
The FSM is a free download so there is no excuse for not using it.
1980 CX500
Fair enough. I’ll look into downloading the factory manual. Thanks for the info
While you're in the Wiki it wouldn't hurt to get the Honda Wire Color Codes chart and the Honda Common Service Manual (& anything else you think might be useful) too.
1 - 10 of 10 Posts
