How does the Weep Hole work anyway ??
it can't really be just a hole though right... does it have a "valve" in there ?
Mine has something in there whether it's good or bad![]()
The weep hole is an early warning feature that either the oil seal or pump seal has started to fail,
if you get oil out - or coolant then you will probably need to replace the seal.
the hole has no valve it is the lowest drain point for any fluid build up..
if your weep hole is blocked - then maybe a PO put something in it to stop leaking (bad move)
I used a small allen or a tooth pick to clean it out. it is just a straight shot.
Mine was seriously pluged solid with that white aluminum rust. I could not poke anything through it. I had to drill it out when I had the cover off to change the cam chain.
A wire coat hanger?Where can I find stiff wire really was the question I asked myself last weekend... I couldn't find any.
I can't say I'm very resourceful though![]()
Thanks for the thought. I think I remember Shep suggesting an old guitar string.
I often use old bicycle spokes for my wire "poking" needs. the spokes also make good parts hangers for cleaning, painting etc...
Many Hobby Shops stock a brand of metal products "K & S." they have piano wire and various metal rods, tubes etc... in a variety of sizes if you need to get a specific diameter.
K&S Metal Products Website
