I always wanted to be rich, but this isn't what I had in mind. My bike is running well enough that I can take it out for runs to the beach and around town, but it is eating gas and coating my plugs with carbon on even a short trip. I'm looking for help in identifying the most likely causes.
This was the project bike that everyone dreams about. The PO simply gave it to me because he thought there was no value in it and that it would never run again. The carbs were handed to me in two boxes containing a number of nicely labelled plastic parts bags. The bike had been parked in a heated garage for 15 years. The PO was the original owner and had kept everything stock and maintained. Using the supplied manual, I put the carbs together best as I could and the bike fired up. With help from Shep and others on this forum I removed and cleaned the carbs a couple times (using high pressure air and carb cleaner), I replaced the spark plug boot innards with brass rods (no corrosion in the boots and the resistor etc came out without issue). I tested the ignition system as directed and all is good. Air box is the original, air filter is clean, there are no air leaks at the carb boots. My idle screws are set to 1.75 turns out. Clean oil and filter, new spark plugs, etc.
Strong spark, great compression and lots of power. Well, lots of power now that I have put low speed jets where the high speed ones are supposed to go!! Before that I was losing all my power around 4500 rpm, but could raise that ceiling to 6000 if I removed the air filter for better flow. Now, with 78 jets where the high speed 112s are supposed to go, I can easily hit 9000rpm in short order.
Everything points clearly to running extremely rich (dry black plugs after a short ride, poor mileage, smell of fuel, runs better with smaller jets, etc etc). Based on my observations, I don't believe the issue is restricted air flow. This leaves me with the conclusion that it is simply feeding too much gas into the mix. I suspected the jets were worn out and replaced them with new ones (78/112) and there was no change in performance. That's when I took my old low speed jets and put them where the high speed jets go. The bike ran well right through the rpm range 1100 to 9000. I was still fouling the plugs to dry black though and I could still smell fuel at idle (there is no fuel leaking from the float bowls, so the smell is coming from the exhaust). I removed the air filter again for better flow and the bike ran smoother and gained at least 15 mph top speed (it can easily hit 90mph. I haven't had the courage/foolishness to go higher), but still fouled the plugs with a dry black coating after a single ride.
So... with 78 jets where my 112s are supposed to go and no air filter, I am still getting about half the gas mileage I should be and fouling my plugs. Where do I go from here? New throttle needles? New sliders? Is there something else I should be looking at?
Sorry this is so long winded, but I wanted to give as much detail as possible. I have searched the forum extensively looking for information on this and haven't found any clear answers or other complaints of such highly rich condition. Any suggestions will be appreciated as I would love to get this great machine running well enough to spend my summer travelling on it.
John
John
