Cleaning and lubing a chain, especially on a "dirt" bike.
Cleaning a "dirt" bike, (right) , after a ride.
About the only thing that really sucks is ajusting the carbs in bike on a standard model. Royal PITA and the supposed tool made for the job doesn't fit.
Lately, any little task has sucked. Anything from checking the oil level to Changing a rear brake light. Thats not always the case though. Its weird I go through these, "Yea I want to tear into it!" to "I just want to ride, not fix anything"
Shep, you never fail to come up with the simplest and most workable ideas. Two projects now tomorrow thanks to you!I've ground off the carb bracket on both sides to allow easier access.It's so substantial as to not be a problem.I've also ground an angle on a small cheap flat blade screwdriver as an adjuster tool.
