Did you check at TR as well? You keep referring to the TL mark but the right cylinder's valves need to open at the right point too.I've checked the timing by bringing the rotor around to TL and the rockers wiggle as they should.
We normally frown on asking the same question in more than one thread because it can lead do confusion but I think in this case it won't as long as the threads are cross referencedI fear something mechanical is amiss. I don't think there's adequate compression for whatever reason. Can I re-use the head gaskets if I need to remove the pistons again? It's never ran and only been torqued the once with Copper Gasket sealer spray.
You can merge the two if you like,Bob.Did you check at TR as well? You keep referring to the TL mark but the right cylinder's valves need to open at the right point too.
Re-use?
The engine I was building over lockdown has failed to start. I've not run a compression test yet but I'm fairly sure that's the problem. Can I re-use the head gaskets and rings if necessary? It hasn't run so it's not been subject to heat or revs above what the starter spins it at. I don't have...www.cx500forum.com
To be fair though, I was just asking if I can re-use certain parts but it ended up a cross reference. Merge or delete as you see necessary, Bob. No worries.Did you check at TR as well? You keep referring to the TL mark but the right cylinder's valves need to open at the right point too.
Re-use?
Not yet, Bob. I have one those lives where my time to do things like that is sparse at best. I'll be posting any results I get from that and compression test as soon as I can get the time. Thanks for lookin' out, Bob.Yeah, I figured this was a case where it might be better to leave them separate as long as they had links to each other.
So did you check that the valve clearances were set at TR compression?
I used moly on alot of the parts that rub. Oiled the pistons/rings on install. Maybe plugs. It blew a feeble flame out the exhaust port when I put petrol in the balance ports. Nothing off the carbs. I can smell the petrol when I did the compression test. Reckon plugs couldn't hurt but it seems to me I should have more happening than there is. I'll give the current plugs a good cleaning for now to see if I get any better results.New rings that aren't bedded leak. Compression before first start will usually be low, particularly if the bores aren't absolutely round. A hone can't fix dimensional issues like minor ovality.
They will bed in and your compression will improve once it's running.
One thought I've just had on your non start.
As you've had this completely apart and presumably assembled with copious quantities of oil are you certain it has not oiled the plugs and saturated the insulator?
Trying another set of plugs might be worthwhile.
Nope. No paint has been applied. I rebuilt the engine over lockdown and just put it in. Once I get some time I'll have a look but all the ancillaries were taken off an engine that has a knock when hot and put onto the rebuild. Knock aside, the bike ran great. Good carbs, good coils, all sorted with the knocking engine in it. It's just one of those "what did I miss?" things. All things being equal, it should at least start.I'll offer something that's probably a long shot and starts with a question - did you paint the frame before re-assembly? I've put a bike together after painting and the the earth / ground was not as good of a connection. It was not noticeable on gauges, lights, switches, but the spark wasn't there and wouldn't start. i pulled all the ignition stuff and someone else said "hey try the ground". Boom! it ran perfect after that. I really coated the frame heavy in a few of the hard to spray places that are not visible to ensure no rust and corrosion. The paint was not a great conductor. Since this started as a potential electrical issue it may be worth just 2 min of sandpaper and reconnecting the ground on the bike. Good luck.
I've been thinking about a tooth off. Do you think I have the symptoms?It’s been mentioned earlier but I’ll bring it up again, are you sure you had the crankshaft and camshaft lined up properly when you installed the timing chain? You symptoms definitely point to you being off a tooth or more.
