Has anyone ordered these spark plug caps from across the pond? My question is: do they come with any internal pieces at all?
I'm doing the brass rod mod but I'd like to replace the brass screws with the bent wire that actually "grips" the spark plug.
Thanks!
They don't have resisters, nor do they come apart. Consider them pre modded.
They don't come with the plug well boot.
One of my bikes has been running a pair for a while and I run DR8eAs.
DSS has them with the well boots, and I think they are also pre-modded, non resistor, but don't hold me to that.
I have run/ran the Wemoto Spark plug caps on both my CX500s for years.No problems.Just make sure you use an,"R" rated spark plug e.g one with an R in the plug code as this means it's a resistor plug like the NGK DR8ES-L
Or the Iridium versions
DR8EIX
HTH :)
