Status
Not open for further replies.
Welcome to the forum (Newbies please read)
1.2K views 0 replies 2 participants last post by  Sidecar Bob
#1 · (Edited)
Welcome to the forum. Please add your location and your bike's model and model year (NOT year first registered as shown as the paperwork shows in the UK and some other places) to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
And welcome to the world of antique vehicle ownership (they own us, not the other way around). Your bike is over 4 decades old and may or may not have had all of the maintenance necessary to keep it safe & reliable so it is highly recommended to download the Factory Shop Manual for your model (available through the CX Wiki - link in my signature) and go through all of the service procedures, regardless of whether your bike has reached the specified mileage.
Note that while aftermarket shop manuals are pretty much necessary for people without factory training to work on a lot of makes & models of bike the FSMs for the CX/GL500/650 family of bikes are so well written & laid out that the FSM is really the only book you need and the aftermarket books are secondary references at best.
While you're in the Wiki it is a good idea to get the Honda Common Service Manual, the Honda Wire Color Codes chart and the wiring diagram for your model too.
I also recommend looking on all rubber parts with suspicion because rubber does not age gracefully. Check the date codes on your tires and replace them if they are over 5 years old no matter how good they look & feel (old rubber simply cannot flow around the irregularities in the asphalt well enough to grip, especially if it is cool or wet). Rubber brake lines should also be replaced every 2 or 3 fluid changes (= 5 or 6 years) so if your bike still has them I recommend shopping for modern stainless braided ones (they last practically forever and double the life of the fluid). And don't forget things like the rad hoses and the boot between the engine and swingarm (they can crack on the bottom where you don't see it).
The best advice anyone can give you about customizing any vehicle is to forget about making it some specific style. Make sure it is safe & reliable in more or less original condition (or as close as is reasonable depending on the condition you received it in), use it for a while and let it tell you which changes are needed to make it do what you want/need better and then put your time/effort/money into those instead of wasting those precious resources on making changes based on style or on copying what someone else (who may or may not really understand how the changes affect the way it works) has done.
Concentrating on modifications that actually make it work better is not only more likely to produce something you really want to keep and use but will also result in something that doesn't look like every other copycat "custom" around. Mods for the sake of style, on the other hand, often result in a piece of expensive yard art that you can't stand sitting on for more than a few minutes and might even be dangerous.
Status
You have insufficient privileges to reply here.
