My uncle seems to have misplaced the thrust washer on the waterpump shaft.Will this cause the mechanical seal to leak or is it to space the impeller away from the case?I (like a dummy in a hurry)assembled the rear cover without it and the weep hole is dripping badly now.However the impeller is not touching the case so my ? is what does it do?Also when I had the rear cover off the mechanical seal came out easily(rubber cups and spring not the metal sleeve).So if anyone has a spare thrust washer or dimensions so I can get one I would appreciate it as I am about to replace the mechanical seal.JUst wish I would have done it when the engine was out.
