Hey all,
Hoping for some help, again.
First of all, I finally have the bike running good! It did not run and sat for about 7 years at a farm (outside) and exposed to all the elements. This being my first motorcycle that I’ve tried to bring back to life, I’m ecstatic.
Thanks to this forum and the help, and parts (thank you Murray).
My only issue now is the leak. Even though I did the quadruple bypass, I thought it was the mechanical seal even after completing the bypass. So I went through and pulled engine enough to get the rear cover off and replaced the seal again, used a new copper washer and new acorn nut, new thrust washer. The leak is not as bad as before when it sits but there is a nice steady stream from the weep hole when the bike runs.
The only thing I can think of is I might have not torqued the acorn nut enough. from memory. it’s 6 - 9 pound feet but I might have been on the lower side of the torque value of fear of overtorquing it.
any other things I can double check or silly mistakes anyone has seen or heard of?
