I have the cover off my water pump right now to change the rubber gasket. I was cleaning the impeller off and noticed that it doesn't turn, only moves a bit in each direction. Is it supposed to turn, or only when the thermostat kicks on?
It was a pain in the butt getting the cover off, I kind of want to make sure everything is functioning properly before I put it back on. I am planning on using a small amount of gasket sealer, as the cover has a tendency to leak I've noticed. Good idea, bad idea?
