Hello Turbo Friends,
As adviced by several of you I decided to take a good look at my turbo so I disassembled the bike to the point where I can see both turbines and waste gate.
The fans rotate smoothly on both sides with no wobble or noticable resistance. However, the waste gate does show a problem. From the pictures you can see
that the valve its self is loose on its arm. When I open the arm I can wobble the valve with my fingers. I don't know if this is how its supposed to be
or if the valve has come loose. Your input as always is appreciated.
