This is the inside of my starter. There shouldn't be wear marks here, I assume (please see picture). Would that mean that the end cap bearing is worn? Looks like the one I got in my rebuild kit is the wrong size.
The outside diameter is too small.
[I apologize for starting yet another starter thread, but I didn't see this covered when I searched.]
The starter stopped working on my cx500, so I pulled it and bench tested it. It arced. So I took it apart, bought a rebuild kit and went through it, BUT I did not replace that bearing. I put it back together and although the arcing has stopped, it won't spin on the battery, and it's lumpy and stiff to turn. (Also checked with an alternative ground.)
So my thought is that I have to get another rebuild kit, this time with the right bearing? Or are bearing like it available individually? Guess I'd need the specs to find one. Sounds tricky.
Or do I simply scrap the whole and try to find a replacement? All I'm finding are $100 used ones that haven't even been gone through... Are there any decent aftermarket replacements I could find new... that will fit right? (79 CX).
I noticed that the goop on the armature stack is worn off one each end too.
Thanks for your time!!!
