Note that the US DOT (& Transport Canada) require a 4"/100mm distance between a turn signal and any other light that is on when the signal is flashing (not to mention a minimum area of reflector that is usually part of the stock tail light's lens) so lights like that are not legal unless you set them up so that all other functions don't work while the signal is in use.
Personally, I think that anything that can allow an inattentive car driver that ran into you to claim he couldn't tell that you were signalling or braking is a very, very bad idea.
IMHO, you would be far better off (not to mention safer) to get a DOT compliant tail light and some nice little LED turn signals and make up brackets to mount them in appropriate locations.
BTW:
