1 - 3 of 3 Posts
Hi guys and girls,
OK, so i'll try and keep this as short as possible. mid-2015 I bought a 2nd hand working '81 Honda CX500 on Gumtree and got to work turning it into the cafe racer of my dreams. The bike ran fine but needed a 'triple bypass' as it had done about 90k miles. I got to work and also got to buying all the parts I would need to re-assemble the bike.
My plan for the CX500 was as follows:
  • CX500 engine rebuild (including trip bypass as mentioned above)
  • Turn bike in bopper or sleek cafe racer.
  • CBR600RR front-end mod with upside-down suspension, disk brakes and low-slung handlebars.
  • Ducatti Fan-mod
  • Battery mod, storing small battery low-slung under-bike
  • Basically tear out the CX500 known bad-electrics and replace it with a small Ignitech unit
  • New carbs, I opted for race-tuned Mikuni carbs from Murray and his custom kit that comes with it.
  • A raft of other stuff as listed in the parts list below :)
I basically took the bike to pieces (carefully), organised it and then started to figure out how to rebuild it from the ground up (shop manuals, the works). The bike then (and now) is almoste entirely disassembled (see photos in google gallery below)
The CG125
Around the same time, a friend ended up dumping his (also disassembled **rolls eyes**) Honda CG125, a bike that was non-running when he bought it in my garage and essentally donating it to me.
2016, stuff goes on pause
2016 was a bad year, and several heavy family and personal issues hit me at the same time so the project was completely paused as I dealt with everything that was happening around me. Cut to now anddddd.. i'm moving to another country. Denmark to be specific. I would love to take the projects with me, but as I'm starting a new job and shifting my family over I know it will end up in storage for another year or two until I get settled (something that will cost too much in Copenhagen)
Long-story-long I am essentially clearing out my garage of everything listed below, and would ideally like someone that will take everything in one go. Essentially what you have here is the kit of parts for a great CX500, where all you really need to add is a couple of small things (a seat for example). The CG125 isn't worth much so i will essentially throw that in for free to anyone that wants to take the whole thing.
You can see photos of everything in the google gallery below:
https://goo.gl/photos/zumpxGdXGMSPFYio8
If you have questions please drop them in a comment below, if you have SERIOUS offers please send them to me in a PM. As mentioned ideally I want to sell the lot in one go, but I will listen to fair offers for the parts as well.
Full parts list (as near as I can gather from 3 years of emails) below.. oh and Approx prices I paid for everything (save you adding it up, its close to £3,200 GBP)
  • Honda CX500 - £700 GBP
  • Honda CG125 - £300 GBP (price friend paid for it)
  • Carb kit - $549 USD
  • Clutch Spring - $13 USD
  • Upswept Exhausts part #MCPBUS - $60 USD
  • Honda CBR600RR front wheel 2013 Wet tyre on wheel - £187
  • CX500 Nut & Bolt megapack - £70
  • Clutch Nut Socket Tool - £12.45
  • 1 x 14401MA1013P - Cam chain - GBP 32.95
  • 1 x 17613413000 - Fuel tank rear mounting rubber - GBP 7.50
  • 1 x 15140415003P - Oil pump chain - GBP 12.95
  • 1 x 9501472402 - Side stand return spring - GBP 2.15
  • 1 x PXP CX500 PAIR - Exhaust downpipe set - GBP 45.00
  • 1 x 19217611000P - Water pump mechanical seal - GBP 25.00
  • 1 x O RING SET 001 - Water pipe O rings - Set of 7 - GBP 7.95
  • 1 x 91251ZW5003P - **OEM** OIL SEAL 14x26x6 - GBP 2.75
  • 1 x 91202283013P - **OEM** OIL SEAL 18-28-6 - GBP 2.75
  • 1 x 90441706000 - WASHER, SEALING, 6MM*B - GBP 0.80
  • 1 x 14500470751P - **REPRO** 10366080 TENS - GBP 17.50
    • 1 x 14620470751P - Cam chain guide blade - GBP 19.95
    • 1 x 91312415000 - O-RING.6.5X3.1* *D - GBP 0.55
    • HONDA CX500 1980 K&N Oil Filter - KN-111 - £6
    • Honda CX500 Ignitech - $327.30 AU
    • HONDA CBR600RR 2003+ 12 STAINLESS STEEL DISC BOLTS FRONT- £30
    • Footrests Yamaha YZF1000 Thunderace 1996-2003 Front FRRYF01 - £15.95
    • FULL COMPLETE GASKET SET FITS HONDA CX 500 A/B - £33.99
    • Ducati 848/1098/1198 Radiator Fan 1,000 miles Only - £12.00
    • Honda CBR600rr front brake calipers radial 2007-2012 pair - £80
    • Honda CX500 - re-cored and repainted radiator - £73.00
    • CBR 600 1000 RR CB 1000 R / ABS CB 1284 1300 SF SuperFour Front Brake Disc Rotor - £135
    • CBR 600RR Top + Bottom Yokes - £140
    • CX 500 FRAME VERY GOOD CONDITION - £50
    • CBR600RR / BLACKBIRD / R1 / R6 Stainless Steel Front Spindle Bolt M14 x (1.50mm) - £5
    • Honda CBR600RR 2007 - 2015 Captive race wheel spacers. Full set. UK made. - £18
    • Honda CBR600RR 07-13 front wheel bearing kit Quality KOYO - £15
    • Universal 7/8'' Motorcycle Bike Handle Bar End LED Turn Signal Light Amber&Red - £13
    • Honda CBR600RR Clip Ons 48mm CNC Handlebars Fit 2010-2011-2012-2013-2014 Black - £69.99
    • HONDA CBR600RR-A 2007-2012 FRONT WHEEL SPINDLE A1 CONDITION CBR600 CBR 600RR - £19
    • Battery Box - £64
    • Steel Frame Plugs - £24
    • Lucas Oil Engine Builder Assembly Assembley Lube 4ozs 114ml - £9
    • Ballistic Evo2 battery - 8 Cells - 15 Ah Battery - £112
    • 2007-2012 Honda Cbr600rr Front Forks Pair Straight Clean - £300
    The CX500 when I bought it:
1 - 3 of 3 Posts
