1 - 2 of 2 Posts
Hi everyone,
I tried reading all the post about tyre size and it didn't seem like theres was my answer:
I have an cx500 1981 standard and I want to put a wider rear tyre on it, anyone can tell what would be the biggest i could fit in the arm? its a 18" wheel.
(and yep i know it will make the turn in different, I dont turn anyway)
Best regards hope you can help ^^
I can't imagine why anyone would want a bike if they didn't intend to at least turn the occasional corner......
I've said it many times: If the change you want to make is only for looks and won't make the bike do its job better (or worse will prevent it from doing its job as well as it would if you didn't make the change) you should put your resources into other modifications that will make it work better.
1 - 2 of 2 Posts
