trying to replace my starter buton ,
and cannot get the twistgrip off.
not enough slack in the cables to just slide it off the bar.
and cant see an easy way to get the cables out of there keyhole possitions.
cheers mark
Discussion Starter · #2 ·
update by moveing the bars to the left an inch in the bar clamps the grip slid off .
but when i took the replacement apart to swop over.
i found it was also broke in one place ,
not enough to fall out but not worth installing.
more thought requred on this one.
Bummer, contact the seller and see if you can get a refund or return it since it was broken?
it wasnt obvius as it was only half broke( one side of the two pins)
so i am going to try and fix it.
cheers mark
Oh, ok. I had a switch would that stick not release - upon disassembly I found one side broken as you have. Good luck with the repair.
