So I went to swap out the front end of my CX with the GL's, almost got done and the ignition switch wouldn't fit, then one of the air inlets broke, so I decided to fix my CX forks, and put it back together, well, I did that, but now my turn signals are not flashing when I flip the switch, the rear turn signal turns on solid, doesn't flash, and same with the dummy light saying that turn signal is on, but there is no flashing..... There are 2 different solid green wires with female connectors, 1 has a male end green wire plugged into it, which didn't affect anything I noticed, and there's also a brown wire, well, 2 brown wires run into 1 female connector, and has nothing plugged into that either, and no other brown wire....
