1 - 13 of 13 Posts
Hey folks! I have new project bike - a 1979 CX500. The PO added LED flashers (and a digital/LED flasher relay). He said it used to work, but it's not working for me. All flashers, front, back, left and right do the same thing. I have attached a video link of what is happening. In addition to the turn signals not flashing more than once, the brake light BARELY gets brighter when I pump the brakes. I assume this is somehow related. Battery is fine and stays charged. Any thoughts? Thanks!
The relay seems busted . If it is, it can not be repaired, as far as I know . Change it with a new one, to see. If it is not the relay, then you at least got a spare you can keep . :)
Reactions: tnewberry
On my bike it is behind the right side cover.
Hopefully it's not too late to mention that LED turn signals require a special relay. The standard thermal relay will not work.
With that gauge, you will also need a diode setup since the gauge indicator light is a single shared LED and no longer separate warning lights.
You can pick up the relay and the diode kit, together, for $13 from Products
Yes, I ordered a digital "LED" relay for $6 on eBay. I confirmed it's compatibility.
The diode on the gauge works just fine, from what I can tell. I'll get the relay installed and check. Thanks.
Both foot and hand lever don't work?
Sent from my iPhone using Tapatalk
Correct. Every light works properly. Turn signals are now working (since I swapped out a new flasher relay). Head lights, high and low work. Brake light is on, but does not get brighter when I depress the either hand brake or foot brake. Any ideas?!
Correct 1157 two element brake light bulb ? Running light might work with brake element burned out. Bulb might be in backwards, it can be done. Switches hooked up and working, power in/out, front switch on brake master cylinder rear is pull wire from brake lever. Power to brake light? Run a jump wire from brake light base to negative terminal on battery to check ground.
Sounds like only the running lights is working and the brake light isn't. Perhaps check the connections to tail light.
1 - 13 of 13 Posts
