2021 Benelli Leoncino Trail - 2021 CSC SG400 - 2017 SSR Buccaneer 250i - Several CX project bikes
I want to use the 500 Turbo's shifter lever on my latest (naturally aspirated) project bike. The Turbo apparently has a larger shifter shaft, because the splines on the turbo lever are much bigger than the stock lever. Can I simply swap the shifter shaft from the turbo into my motor, or is the hole a different diameter with a different seal? Thanks.
Charles.
Charles.
