I started the triple bypass process on one of my 2 turbos. Learning a lot about the bike.
Anyway, Engine is out. That was an interesting experience but it actually went pretty good. I did not set any speed records, LOL. But it is out.
I have questions in the following areas:
1) I cannot get the dowel pins out of the water pump cover. THey seem to be rusted in. I also had trouble with the impeller and the sensor rotor, but I have been hitting them with Liquid Wrench which has been working for me in general. Got these parts off after letting the Liquid wrench do its thing. However, I cannot get the dowel pins out.
=> Do I need to get them out? Can I just reuse them? THey look like they would clean up nice, but I do not want to risk chewing them all up in the process of trying to get them out.
2) In general, I am having a very tough time splitting cases. Obviously, I did manage to get hte water pump cover and body off above. In this case, I used a rubber mallot to tap them off. But I CANNOT GET THE REAR COVER OFF.
=> How do I split the case of the rear engine cover?
--> I have followed the service manual to the letter and it in general has been very helpful except in the area of where it says Remove such and such cover. I have now removed the bolts from the rear cover and I cannot get the case split. Even all
the threads do not discuss this. They typically just magically show that the cover is removed. Does everyone have trouble with this or am I doing something wrong or missing a special tool or something.
--> Is there some sort of trick to the process? I have been using the rubber mallot approach but have had no luck.
Any help or questions would be appreciated.
John
John
