Hello Everyone!
A while ago I bought a burned out CX500 with no airbox and a cut wiring harness, and figured it was a great candidate for a custom bike. So fast forward a lot of work and a lot of fun later, it is running and I take it around the neighborhood, but I feel like I am not getting full power to the wheels. Come to find out that when I am in first gear with the clutch fully pulled in the bike still coasts forward slightly (is this called clutch slippage?)
So I read some other posts and get some things to check, so I pull the clutch out and it looks like this:
I don't know the verbage for any of this so bear with me if you could.
OBVIOULSY, there are two broken... thingies.... that go on the rear plate which I imagine resulted in incorrect pressure on the plates and thus power was never fully disengaged. There were signs in the transmission that it had been removed before, namely that the nut holding everything in (that 4 pronged nut) had dents in it where it had obviously been chiseled off.
So here come the questions:
I need to replace that rear plate, anyone know where I can get one?
I have the clutch plates and friction plates aligned in order that I removed them, what thicknesses should they be?
Should I thoroughly clean everything before putting it back in?
Should I oil up the plates when I stick them back together?
If my thicknesses are out of spec then where can I get some new plates?
What are the torque specs for the 4 pronged bolt?
What are the torque specs for the 4 bolts on the springs?
Any feedback is greatly appreciated.
Thanks,
~Austin
Thanks,
~Austin
