Just consider it a 40k service.Most have us have or will come up against this lack of maintenance.As a matter of course if the Cam chain adjuster slot shows less than half left you may as well change the Cam-chain if you have the time and money.
The picture on here was BlindStitch's(Don) I think and he caught it in time,
http://www.pdsrecording.site90.com/cxgl500/noises.htm
If there were no copper flecks in the oil you should be ok.If the bike had no bad knocking before the strip you should also be ok.
What you need to do is make sure before re-construction that all metal debris is removed.As this is not a full strip down to the crank I use a car power washer or jet garden hose to flush the engine with some washing up liquid to degrease.I use it on,"Fan" and carefully for the rear case.I then high pressure air blow it dry as I have a small compressor.If you don't have one some friendly local bike shops/tyre places may let you use theirs or even a Hair-dryer/Hot Air blower can warm the engine up to stop parts getting rust on them and there's no harm spraying parts after a wash/dry with some WD40 type stuff as a temp anti-moisture film whilst you work on the engine.
As for the stator the thing is electro-mechanical parts have a life expectancy of between zero and infinity.No one can say how long a device may stay working or fail.If the Stator passes the tests on here
http://globalcxglvtwins.hostingdelivered.com/viewtopic.php?f=8&t=30
http://globalcxglvtwins.hostingdelivered.com/viewtopic.php?f=8&t=298
and you had no relevant charging problems re-use at your discretion.
HTH
HTH
