In my quest to get my bike running, I have cleaned the carbs as complete as I can using shep's method. I still don't know if htey are right but i thought they were. The bike wont hold a charge or start. when it did start, it missed from idle to about 3500-4500 rpms on the right side. Change cdi, coils rectifier/regulator, 2 sets of carbs, spark plugs, wires & boots,and still wont run. So I pulled the engine with only 23,000 miles on it for "triple bypass". Water pump seal was in great shape and cam chain tensioner were the latest style and also in like new condition. after pulling the stator I noticed 2 of the 'loops' were black and i couldn't see the wires under them. But it tested good in all of the resistance tests. The new/used stator i was puting in tested good and looked good until i got the engine back together. Now from one of the yellow wires to the engine case I get a reading of 1800-1900 ohm resistance ocasionally. My latest delima is if I should put in another stator, the one that fails the resistance test, use the one that passed all of the test and try to clean my idle circet in the carbs again. or load the bike into a missile and blast it to the moon.
Any thoughts? I think the one i took out was good but the 2 'loops' have me concerned. It only has 23,000 miles on it. Maybe if I post some pictures someone could help me decide?
