Sometimes a tap and "push/pull" on the grip/ throttle tube is enough to get it snapping shut again....(might be binding in/against the switch housing)
Hmmm, I disassembled the whole housing and tugged on the cables by twisting the throttle repeatedly, no dice. Makes me wonder if the little metal L shaped ends could’ve gotten bent right before they lead into the housing.Sometimes a tap and "push/pull" on the grip/ throttle tube is enough to get it snapping shut again....(might be binding in/against the switch housing)
There are two screws on the bottom of the killswitch housing that holds the throttle tube on. I did back it off the bar end and it has remained the same unfortunately.Cant remember if theres cross screws or a allen holt holding in place..(the switch halves), as Im away from home ATM.... try backing it off and see if that changes things.....if so its how things are aligning....
That is absolutely genius, I will give it a try this evening after work. Should help me diagnose it. I will say that last night after disassembling the assembly, the throttle tube did seem fairly free spinning on the bar, sliding from side to side, tension coming from the cables. Reading others horror stories about replacing the cables certainly doesn’t inspire confidence, so fingers crossed.If you remove the throttle cables and reinstall the grip assembly (tighten everything down, not just mocked up), does it turn freely? Usually either the throttle tube is damaged or the throttle got pushed inwards on the bars so the inside of the "cap" part of the grip is now rubbing on the end of the bars. I've seen the end of the bars get deformed as well, but usually other stuff breaks first.
If the throttle checks out, then you're left with the throttle cables. Do each of them pull freely? Are they adjusted properly (pull adjusted for minimal play, and return adjusted with a decent amount of slack so they aren't fighting each other). It is possible the tubes that go into the throttle housing got damaged when you went down.
Ideally youll have to replace that front panel(ebay or forum gift).... all temp repairs with sealant etc might work for a while but not for longAlrighty, with the advice given by @LC8Adventures I was able to get the throttle all fixed up, snapping shut good as new. I thought I had a spare brake lever but will need to order one in. I also just found out that my delicate torque wrench use was just about pointless, as a previous owner clearly had cracked case right at the oil plug. It held up just long enough for my recent oil change, and the resulting oil spill was the root cause of this whole mess. sigh I guess it's back to the auto parts store for a sealer of some kind, and then to search for a new brake lever, but at least now I know the cause of what made me to slip and drop the bike in the first place. Thank you all for helping, it feels good to be back in action.
Sheesh, yeah you’re right. Looking at the hack job done by a PO, my front engine cover will need to be replaced sooner than later. I’m thinking I’ll switch to a magnetic style plug at that time as well. Hopefully today I can stop the leak up until then.Ideally youll have to replace that front panel(ebay or forum gift).... all temp repairs with sealant etc might work for a while but not for long
After that torque wrench AND new washer at each drain..
A little bit of JB weld SteelStik seems to have gotten it back to the condition I bought it. Will keep my eyes peeled for a replacement front cover. Opening up the actual engine is where I start to feel intimidated, but what better time to learn I suppose. Although if welding is a viable fix, I'd just as happily pop by to visit @Randall-in-Mpls one of these warmer days.I wonder if a MAPP torch and aluminum solder wouldn't make for a reliable repair? I'll help if the consensus is that it's worth the attempt.
