1 - 13 of 13 Posts
Hi all, After tearing apart & cleaning the carbs on my "Commuter" '80 CX 500D I picked up when I was rebuiling my totaled my '94 VFR. I was hoping to improve the throttle response. She has a little over 25k on her now she was at 21k when I picked her up. After going through the carbs, I was about to put her back together when I pulled on the end of one of the cables & it kept comming
So now I need to replace both, does anyone know of a direct replacement? or is it time for me to create my own or replace with another throttle assembly?
Thanks in advance
Gary
V-FORE
Thank you all for your help...I can't believe that I did not even think of E Pay, thanks for showing me the trees through the forest
Gary
Motion Pro still makes ALL the cables for CX500's (or at least the 80 CX500D). Any local motorcycle shop with a parts catalog should be able to look it up. I usually do it this way since they can get the cables in 2-3 days. Local sales tax vs. shipping is pretty much a wash.
well did both cables break? or just one i know a lot of people on here only run one cable if the spring is strong enough on the carb it will pull the throttle closed
The B push cables are there for a purpose.The springs in constant velocity carburettors are not very strong by design and the B cable helps close the slide on throttling down.There are a few,but not many,people who may run with just a single A cable at their own risk.
· Premium Member
That's only to get you home, where you can fix it correctly. I wouldn't trust it as a long term solution.
R
i have ran with only one cable for about a year now and no problems hell even blindstich runs one cable
Anyone ever get the Motion Pro's? I know they have a good reputation, but I was wondering if they have the OEM style Chrome ends, the ones on MoPro's site are all black.
It's a mixed bag -
Throttle cables
carb-side = chrome, handlebar-side = black (with black adjusters)
Instrument cables
sending end = black , instrument end=steel (not chrome)
Clutch cables
clutch-side = black corrugated rubber boot, handlebar-side = chrome tip (hidden by adjuster though)
At least from my experience ordering for 1980 CX500D from my supplier...
1 - 13 of 13 Posts
