I was riding home several weeks ago and the bike had been sounding odd. I thought it was the packing coming out of my aftermarket exhaust, or the pernicious exhaust leak that I had been dealing with, only worse. The day that the bike died I noticed that I lost most of my top end power and under load it was making a loud noise that, as mentioned before, sounded like an unpacked aftermarket muffler. As I got closer to home I noticed that I was slowly losing speed and power with the same throttle position. I thought my battery wasn't charging, but then thought maybe there was a new problem with my electrical system. I tried to take her past 5,500 RPM to see if I could pull her out of her funk and right around 6,000 RPM I heard a couple sputter sounds and then the bike died. The battery hadn't enough voltage to run the starter, which made me think it just was not charging. I charged the bike and started it the next day and heard a wretched thud or clunking noise from the right cylinder. At that point I thought that perhaps the cam chain, which had reached its service limit, had not been tight enough, and had allowed a valve to be open when it ought not to be. After a compression test revealed 80 PSI on the right cylinder I thought this was clearly what happened. Unfortunately, after pulling the head and inspecting every valve on the right side, I was dismayed to discover they were all in fine condition. I now have no idea what would make a sputter sound, cause the bike to die and lose charge in the battery, make a clunking noise, and cause low compression on the cylinder. The pistons look fine, the cylinder walls look fine, there is no slop in the rocker arms or pistons, the push rods are fine and everything seems to move freely. Any ideas?
