Papito,it looks to me as though you are running very leanperdon?![]()
mm,to me yes,id be concerned if my plugs looked like that.hence my mpg joke,,,running on fumes.I think you’re very right. Lean=not enought gas right?
Larry,is 5 miles enough to draw mine/his and your conclusionsThose plugs are telling two stories. But I'm not sure which story to read first.
Yes, they are running lean. That's why only the tip of the plugs have burnt off the carbon deposits. That in itself will cause a hot spot that's hot enough to burn a piston of valve if you run it this way long enough.
The second story is that either you were running it with the choke on while it was in the garage sitting on the stand which caused the rich condition before you started riding it for the 5 miles, or one end of the system is already running too rich. I think it was the first guess though.
Without enough fuel to do a full burn in the chamber the plugs will only do a quick burn and not build up enough heat for the carbon to burn off the entire plug. Bandit is right though and so are you. You NEED to re jet it before you burn up the motor.
next test Papito,a minimum of 15 miles,give the motor a chance to warm upok I won’t. Thanks again for your expertise.
