So I have flushed the system thoroughly, added sufficient 50/50 mix, built the Green LED "REG"ulator, measured the green/blue lead and am getting a solid 6.99V with the iginition on, All contacts are shiny clean,...the guage is nearly unresponsive.
The Thermostat housing and the cylinder feed pipes are both HOT...so hot I can't keep my fingers on them...maybe 175?F I may borrow a infrared thermometer from my Uncle, but what do you guys think?
I am guessing a couple things are going on...
I would think the sender is going bad or working intermittantly, AND the thermostat is not opening...
How long should it take for the gauge to settle into its normal temp?
