1 - 20 of 30 Posts
This journey began in October 2015. I watched the ad on CL for about 2 weeks, the offering was $500. From the pics, the bike looked to be in rough shape but ran. I saw it drop to $400 one afternoon, so I decided to inquire. Guy told me he was going to Florida at the end of the week and didn't want to pay for storage. He was very eager to get rid of it. Talked with my wife and she shot me down. Told the guy that if he still had it at the end of the week to give me a call. He calls me the next morning and says "$300 by the end of the day and its yours!" Plead with the wife, but got shot down again. I went about my day, little pissed off that I was not able to take advantage of this awesome deal. Later in the afternoon he calls me again, tells me that he has had 2 no shows through out the day. "I tell you what, if you come and get it right now, $200." So I took off work an hour early, grabbed my dad's trailer, dropped by the ATM, and went to pick up my new CX500 for $200!!! (I did't ask the wife this time :) )
My daughter sitting on the beast when I brought it home.
She didn't start the greatest and the battery did not stay charged. I was only able to put on about 5 miles before I put her away for the winter and started tearing into it. I did a bunch of research on the forum and was able to find out that my stator charging coils were shot and I needed an Ignitech CDI. Also, the rear shocks were toast, needed new tires all around, and I was not a fan of the fairing, so I would need a new headlight and turn signals.
After obsessively looking at other CX's for a few days, I decided that I wanted to do a scrambler. I grew up on dirt bikes and live next to a bunch of woods, so I thought having a road bike that could also go off-road would be perfect.
Here she is with everything tore off
Took a little doing to get to that point. Who knows how many PO's this thing has had. I found out that most of the parts that were on the bike were from other years. The only thing from '78 on the bike is the motor and frame, everything else had been "upgraded." Even a little rebar welded to the frame to mount the fairing
That's it for this first post, I will be adding more in the next few days.
Not done yet. Ill have another update tonight.
The purpose of this build is to have a reliable, daily driver that I can have a little off-raod fun on when possible. Not looking to do heavy modifications, just enough to make it my own. Plan on keeping it stock with no frame modifications. Oh, it also has to be 2 up so I can give rides to the wife and kids.
She just sat through December, January, Febuary, and March. Too cold and I didn't have any motivation. I am kicking myself for that now, now that its warm and I still don't have a ridable bike. Toward the end of March, I finally got my wood burner installed in my shop, so I got working on her again.
While she sat though, I bought parts:
Duro HF 90 Median Dual Sport rear tire - 16"
Shinko 705 front tire - 19"
Rear shocks off ebay - 13.5"
New hoses for radiator
New radiator bolts
I had the tires installed on the wheels by a local shop. Front tire ended up needing a tube, I was a little confused because I thought they were tubeless. Rear didn't need a tube, guy at the shop said they were from different year bikes. I decided on these tires becuase I will mostly be on the street, but I live on a dirt road and want to be able to do a little off-roading as well.
The radiator was a headache. On the last ride before I put her away for the winter, I noticed something coming out the radiator overflow hose. Didn't look like that was suppose to be coming out, so figured the radiator will need flushed as well.
The PO had installed the wrong size hoses , so the bolts didn't line up with the holes on the frame. Their solution, tap new holes into the frame about 1/4" away from the original holes. These tapped holes royally messed up the bolt threads. I found some hose from my local NAPA store that was similar in size and had similar bends. I was able to get everything lined up properly and new coolant installed.
Front shocks were a little soft. I dont want to rebuild them right now, so while I had the front tire off, I went ahead and replaced the fluid with actual shock oil. Hopefully that will last me through this summer and then I can rebuild next winter.
On April 1st, I was able to get the old rear shocks off and new ones installed. I wanted a little more height in the rear and also some more travel when I do take her off-road, that's why I decided to go with little bit bigger shock. I hope they work out alright, I have read really good reviews and really bad reviews, guess we will wait and see.
Here she is with the new tires, radiator, and rear shocks installed.
Mid April I finally decided on a front light and turn signals. I went with a set of dual head lights and small bullet style turn signals, both from ebay. The electronics are my biggest fear. I don't have a lot of experience and it just seems daunting. I put off doing anything to the bike for about a month.
I started a help thread HERE to get some advice on the wiring of the headlights and turn signals. The PO had really done a number to the wiring harness to get that fairing rigged up, another reason I was nervous. After the help through the thread I started and staring at the '78 wiring diagram until my head was going to explode, there was light!!
That is currently where the bike stands. The goal is to get it in ridable conditon this summer. I will take care of cosmetics in the winter.
To-Do List:
Purchase rear brake light
Purchase new turn signal flasher relay
Purchase new battery
Permanatly wire lights and turn signals
Purchase carb kit
Clean carbs and install
Modify seat pan and make new seat
Future mods:
Renthal 7/8" handlebars
New exhaust
Custom "number plate" to hide headlight wiring
New paint
Wheels are from the same model year(s). Those are "reverse Comstars" - stock Deluxe / Custom wheels.
The interesting bit is you say you have a 1978 Deluxe, except that model wasn't available until '79. You likely have a '79 (or later) Deluxe, as I don't reckon they would have put the reverse comstars (19" F, 16"/18" R) from '79-'81 on a '78 Standard, which had Comstars (19" F, 18" R).
https://motofaction.org/motorcycles/honda-cx-gl/cx500-wheel-differences-honda-cx500-gl500-cx650-gl650
It may be a frankenbike. Perhaps a PO had a titled '78 frame and a complete, but untitled, Deluxe.
R
You're right Randall, that's why she's call The Mongrel.
HERE is my introduction thread where I talk about it. Frame and engine serial numbers are '78. Someone swapped out all kinds of parts on this thing and then someone else added more.
Past due update:
In mid August I finished cleaning the carbs and got them back on the bike. Thank you Larry for your awesome carb guide!
Here she is running after getting the carbs installed
In early September I got the turn signals installed and turn signal wiring routed. I could not get the signals to flash,so I figured I needed a new relay. Took forever to find a decently priced "original" relay that I thought I needed. After finally getting it, I hooked it up and no still no flash. I was pissed because the relay was like $30. Asked around on the forum a bit and someone suggested a cheap relay from Autozone. Would you believe it, the $5 aftermarket relay did the trick! I was a very happy man when those signals started flashing.
At this point The Mongrel was ridable!!! She doesn't look pretty, but thats why she's called The Mongrel.
First couple rides were only 5-10 miles. I would bring her home and put her right on the battery tender. I decided to take her on a longer ride, about 30 miles. Everything was running great until I got about 5 miles from home. I went to signal a turn and got nothing. No signal, no dash indicator, nothing. She started to run weird and thats when I knew, no juice. Didn't make it home and had to call my dad to come pick me up with the trailer. Stator is bad. Time for a triple bypass.
Discussion Starter · #10 · (Edited)
The Mongrel sat for all of November and December as I collected parts for the bypass. I am lucky to have a pretty awesome father-in-law who was kind enough to get me 90% of the parts I needed for the bypass. He got me a new G8 stator, cam chain, mechanical seal, thermostat, tensioner, and most gaskets and seals!
Teardown started on 12-27-16
Some yummyness
And we are in! For the most part, everything looked to be in decent shape.
Got the flywheel off and was able to get a good look at the cam chain and tensioner. I would say tensioner and chain are shot!
Turned her around and took off the fan. This "washer" was sitting just like this when I pulled the fan off.
What the hell!?!?!?
Went ahead and ordered a new fan and fan bolt, the old one is in bad shape, surprised it was still in 1 piece.
This weekend I was able to get the mechanical seal, new stator, and front and rear cases installed.
I had to bore out the rear case for the larger mechanical seal. Using a Dremel 504 flap wheel, I was finally able to get it bored out enough for the seal to fit. After 1-1/2 hours, 5 tries, and many choice words, it is in! Also new oil seal.
New Stator (Thanks CustomRewind)
Here it is right before the rear case was put on.
Hope to get the fan and cooling system installed tonight. Getting close to hearing her run again.
I'd say it was poorly maintained. And if that's the chain that caused the damage, it still isn't adjusted properly, judging by the small amount of the adjustment slot visible below the bolt.
If that is adjusted properly, the PO installed a new chain at some point. Not sure why you think the tensioner is bad.
R
Randall, the pic you show indicates very little, if any, adjustment of the tensioner left. There is no gap left on top of the bolt. Here it is after the new chain and tensioner replacement. I agree, though, that the old tensioner seemed to be in decent shape.
A stretched chain will show a bit at the bottom. If the pic shows it properly adjusted, there's still a little life left in that one. Not that replacing it is a bad thing.
If this chain did that damage to the case, it's because it was slack (not kept properly tensioned.). Stretched chains don't chew engine cases. Slack chains do (and stretch.)
R
Discussion Starter · #16 ·
Thanks for all the info about the cam chain. I just suspected that since the chain was eating into case that it was a bad chain and tensioner. Looking at the old tensioner now, it doesn't seem to be in that bad of shape. Went ahead and replaced both anyway because I had them.
Discussion Starter · #18 ·
Last major replacement of the winter will be the steering stem bearings. Went ahead and got the AllBalls tapered bearings. I was able to get the old races out of the headstock with little issue. The bottom race that was stuck on the steering stem took a little more effort, but finally came off.
I got the new races seated into the headstock by putting them in the freezer for a little while.
Now I am stuck. I can't get the bottom bearing to fit down onto the steering stem. I put the stem in the freezer for over 2 hours and still can't get the bearing pressed on. Anyone have any suggestions for me?
Probably could clean the area where the race fits with solvent, sandpaper and maybe steel wool, maybe a fine file,
the old one came off hard and the new one will go on hard. Some grease may help.
1 - 20 of 30 Posts
