Hey all, I'm having a bit of a problem with my headlight today.
Here's the story...
After work, I headed to my mom's house to pick up my bike, which is where I keep it to take the train to work on nice days. Well, about a half of a mile into my ride, I noticed my reflection in a shiny cargo van. I immediately noticed that the headlight wasn't working. So, I pulled over to try to figure out what the issues was.
I start tinkering with it and figured the bulb is blow, but trying to hit the high beam switch didn't turn it on, so I knew it was something else. I immediately grabbed my tool kit, which though cheap, thank God it was there.
I took the headlight out of the shroud, and pulled the bulb. The filament for both beams was fine. I looked at all my bullet connectors, and with the exception of a loose one, which was still making contact, all was good. Still no headlight though. I check my fuses, and all are good. Check the main (though I knew it couldn't be it), and it was fine.
So, I was ready to throw in the towel, and ride back to my mom's house on side streets, hoping a police officer wouldn't catch me, and bum a ride home. Well, I turned the key to the on position, and the headlight suddenly came on by itself. So, I left it on (didn't start it yet since I was on an incline and wanted to leave the bike in 1st gear) and geared up. I hit the start button, and the bike started just fine, but the headlight went out again. I turned the bike off vial kill switch and proceeded to start it again. Headlight is still out. I did this a few more times, and the headlight went on, and stayed on for the rest of my 12-mile ride home.
So... any suggestions on what could be the issue? To the best of my knowledge, this is the first time this has ever happened to the bike since I've owned it. Now, it did rain something fierce on Friday, and the bike got soaked since the rain started just after I got home, and the bike was too hot to cover up. I left it uncovered over the weekend, and today was my first ride since then. Maybe that has something to do with it? I mean, this isn't the first time it rained on the uncovered bike, but then, it did rain hard and it did dump a lot of water on the bike.
I know the headlight worked this morning. In fact, when I turned the key to the ON position, the headlight came on immediately (the bike faces the house, so it's hard to not notice it). When I hit the starter button, the headlight did go off, but came right back on once the bike started. I can't recall if it's ever done that before, but it's something that I noticed this morning.
Does anyone have any ideas as to what the problem could be, and would you all think I'm in the clear now, or should I continue checking stuff out? I do not claim to be good at wiring, so I will definitely need the "idiots guide" to it if that is something that I need to check.
Thanks all,
Dan
Here's the story...
Thanks all,
Dan
