Hi there. Thanks for all the Information you provide. It has helped me tremendously in my first custom. I recently purchased a GL500 with under 30kms on the clock. It definately wasn't looked after very well but I see something great every time I look at the old soldier.
Rides great but has issues off the bat that I'm hoping you could help me with. Firstly I have noticed the rear mono leaks out very quickly. is there a fix for this or do I need to find a replacement for it? Secondly, would like to for sportier front forks and was thinking of using gsxr 600. I have read that they are relatively easy to fit? Thirdly I have fitted pods with a breather pod on the end of the pipe exiting the crank. Hope this is correct. Do I need to fit larger jets or can I work with the jets I have by adjusting fuel/air mix. Didn't mention going with cafe racer look as previous owner had already chopped away at the chassis. Tail lights as well as back lights for the cluster don't work and most importantly neither does the tell gauge. Hoping there may be a way to test without removing thermostat?
I appreciate everyone that helps and even those who try to help. PS. Parts in South Africa very difficult to come by
Kind Regards
Phil1982
Kind Regards
Phil1982
