I found the reference to the double coil recommended by Murray. It is made for use on Harleys and from information found online the middle terminal connects to + from the kill switch and the terminals on either side connect to ground through either an electronic ignition (TI, Rae-San, Dyna &c) or points.
I have recently seen the reference to using a Harley Davidson coil. Did a couple of searches with nothing, but all i wanted to know is this possible? Can it be used on CDI as well as Ti? and what coil is it? Thanks in advance
www.cx500forum.com
To use this coil on a GL500 you would connect the black/white wire to the middle terminal, the blue (left) wire to the terminal on the left, the yellow (right) wire to the terminal on the right and the spark plug wires to the sockets corresponding to the blue and yellow wires
Note that the single coils with 2 outputs have 2 input terminals as shown in the pic below of the GL1500 coils ready for installation on my GL1100 (6 years ago and working fine). One terminal of each coil connects to the black/white wire for + voltage from the kill switch and the other finds ground through the electronic ignition (normally TI but mine has a Dyna S) via the blue or yellow wire.
NOTE that this type of coil will NOT work on the GL500
